Sheet metal forms
Sheet metal forms
Sheet metal forms
I have a part that has two forms in it already, they are in opposite directions of each other. I need to put another form in it for some strengthening ribs. Is it possible to form a form in wildfire 3.0?
RE: Sheet metal forms
As far as I know, you cannot form over a form because the assembly surface is not flat anymore. You can change the original form to have a new rib or channel across it, then really it as one form. This you can do.
Steve
http://www.3dlogix.com
