Pressure design of piping for external pressure - ASME B31.3
B31.3 refers to the Sec VIII Div 1 procedure for the external pressure
calculations. The allowable external pressure for a given material is
primarily depended upon the thickness of the shell and the length between
the stiffening elements along the length. How is this length, along a
piping run, determined for a calculation. Curved and mitered sections are
also to be treated as equivalent straight sections.
I could not find any reference in the code interpretations,
http://cstools.asme.org/csconnect/pdf/CommitteeFil...
RE: Pressure design of piping for external pressure - ASME B31.3
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
