Built out to obtain full throat thickness
I have heard this term used in reference to the use of a 1/4" fillet weld, to weld a 1/4" plate to a thicker plate. The AISC specifications indicate the maximum size of a fillet along edges of material 1/4" in thickness or greater, is 1/16" less then the thickness of the material unless the weld is designated on the drawings to be built out to obtain full throat thickness.
How is this type of weld designated to be built out to the full throat thickness? All I have ever seen is the use of a standard 1/4" fillet weld symbol.
RE: Built out to obtain full throat thickness
The symbol would be such that you are specifying a fillet and adding a convex surface contour.
EJL
