Torsional Yield Stress
I have calculated the maximum torsional shear stress in a round tube and now wish to check that the material I choose (steel, type to be decided) will not fail.
Materials data tables give you the tensile yield stress, or 0.2% proof strength. Is there a rule or formula to convert the tensile yield stress into a value used for torsion?
Thank you for your help.
RE: Torsional Yield Stress
Torsion induces shear.  Shear and tension are related by various failure criteria.  A popular one is the von Mises criterion.  An Internet search will provide you with what you need.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
