JIC Swivel with Anti Rotating Lock
Guys,
At the moment, i am looking for the mention subject product.
Can you provide me an information on the technical and manufacturer ?
Thank you in advance
KR
RE: JIC Swivel with Anti Rotating Lock
I would check with Parker-Hannifin I believe they make a JIC fitting that locks. If you are near a big distributor of Parker fittings you may get a quicker answer. Parker has a humongous number of fittings.
Another company that may have a locking fitting is Imperial but I can't locate their website. Probably gobbled up by somebody.
what do you mean by anti rotating lock?
I didn't see anything unusual in the IE link.
KR.....
Need more information from you regarding JIC 37 degree fittings, such as: size (example -4, -6, -8, ie...) and what are your application pressure requirements?
