Chilled Water Line Hanger Rods
I am dealing with the following situation on one of the projects we designed. During punch list, we noticed that contractor supported chilled water pipes to the bottom of a sloping roof beam (the beam span is perpendicular to the roof slope; the beams are 16 inches on center). The contractor bent the all-threaded rod and bolted it to the bottom flange.
The detail we supplied utilizes an angle that is bolted to three roof beam bottom flanges and the all-thread rods were to bolt to the angle and we called for beveled washer under the nuts.
I do not think what the contactor did is a good practice since it will introduce bending to the rod. Our company is being challenged by the contractor and owner to leave it as is.
As I look, all I can find is the 2004 RCSC specification section 6.1.1 which reads as follows:
"Sloping Surfaces: When the outer face of the joint has a slope that is greater than 1:20 with respect to a plane that is normal to the bolt axis, an ASTM F436 beveled washer shall be used to compensate for the lack of parallelism."
I would like to get my hands on a documented reference (established one such as AISC manual or publication) so I can show them written documentation why they should change it. Does any one have more details or references?
Please feel free to comment on this situation as well.
Lutfi
RE: Chilled Water Line Hanger Rods
Lutfi
Lutfi
smb4050 is right. Hanger rods subject to axial tension and bending do not follow classical mechanics. If you have any expansion/contraction of your piping system, the bending stresses can skyrocket under tension.
Bending a rod at the thread is such a bad idea, you may have trouble finding anything written on it. First of all, the machining of the thread has created a stress concentration around the circumference of the bar. OK, so there are zillions of threaded parts doing just fine. But bending the threaded bar into a permanent set means the material has been strained beyond yield across the stress concentration. Unless the material was properly heated before bending, I would expect there to be cracks at the root of the threads.
