STAAD modeling question
I posted this over in the STAAD forum, but it does appear to get much activity.
I am modeling a shear wall in STAAD using surface elements. Each floor height of the shear wall is broken into a surface element which is then discretized based on my prescibed fineness.
My question is how do I continuous supports along the bottom surface element of my shear wall that is connected to the foundation. It seems that it will only let me apply support to two nodes that form the bottom corners of surface element. But, I need it put supports along all of the additional nodes it created along the bottom side when the surface element applied my precribed discretization. I would greatly appreciate it if someone could offer me guidance as to the proper way to do this. I hope I have explained the circumstances clearly enough.
Cheers
Cheers
RE: STAAD modeling question
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
