fill surface on imported geometry problem
hi everybody,
i have an imported igs, which i want to add a fill surface feature to it, but the boundary edges are broken as you can see in this image.how can i fix this boundary?
[IMG]http://i34.tinypic.com/2ahiofl.jpg[/IMG]
RE: fill surface on imported geometry problem
You can first try the join command on all the edges, there is a merging distance that will close small gaps.
