Section Modulus for non-homogenous steel section
Does anyone know how to get the section modulus of a built up wide flange with a plate welded to the bottom (different yield stress)? Is it need to make any modification from normal calculation procedure?
Thanks in advance~
Thanks in advance~
RE: Section Modulus for non-homogenous steel section
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
If you need the plastic modulus then you must account for the different yield stresses. The procedure, GregLocock, is not exactly the one for reinforced concrete, as in that case the difference in Young's moduli are accounted for.
As the plastic modulus is normally calculated by determining the plastic neutral axis that divides the section into two halves of equal areae, the same procedure is adopted, but the area of one of the two materials should be weighted by the ratio of yield stresses.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
