Trying to locate plastic gear design house
Not sure if this is the correct forum for this question. My apologies in advance if I'm posting in the wrong location.
I'm trying to locate an engineering house that has experience designing small transmission boxes, using molded gears. I'm developing a timing mechanism for a disposable device that's about 1/2" square
Any leads for this is appreciated.
RE: Trying to locate plastic gear design house
www.akgears.com
Or in the UK
http://www.muffettgears.co.uk/
http://www.davall.co.uk/
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
Thanks for the info!
Plasgears- Do you have more specific info? I do a lot of traveling to MN area, so it would be convenient. Again I'm looking for very small plastic gears and gearbox, ie something that would be found in a small toy.
I recall the initials SPM for S...Plastic Molding. Good house in Minn, MN.
