Create a library feature with SolidWorks 2007 API
I have made a part and I'm trying to save it as a library feature using a macro command. There is a sample in the SolidWorks API help, how to make the macro but it didn't help me. Any idea,please?
RE: Create a library feature with SolidWorks 2007 API
First select the feature that you want to be a library feature.  Then use ModelDoc2::Extension::SaveAs.  Specify the extension ".sldlfp" on the filename.
-handleman, CSWP (The new, easy test)
I've tried it but I didn't have a positive result..,Have you done it? Can you write the code for me,please?
I change the part to a feature( with .sldlfp extension), as you advice me, but then when you insert the new feature a message telling you that the "Feature Library is empty" appeared on the screen. What I should do?
No, you are wright..!! It is ok! I don't know what I did wrong but now I think that it works... I'll kill myself!! All day I'm trying it and now it works!!I'll see it again tomorrow, thanks for now..Any idea how I can insert it to a part or assembly? Many many thanks!!!
