Block Insertion Nodes Showing
Has anyone had a compatibility problem with block insert nodes becoming unusually large when running AutoCad with Bentley AutoPlant.  The nodes will shrink if I regenerate the drawings; however, they will not completely go away.  The blocks that are creating the problems are objects that are 3D solids or surfaces.  When attempting to print the objects, a very small box appears at the insert point.  Any suggestions of how to suppress the insertion points?
RE: Block Insertion Nodes Showing
Hi CRG,
Set PDMODE = 1
HTH
Todd
Thank You TCARPENTER1
That was my problem.
