Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"Because of this forum, I continue to WOW! my clients!"
Geography
boltsandvolts (Electrical)
5 Sep 08 11:14
Hello and thanks in advance,
I am trying to determine where are some internet sites for helping me determine:
1) How to correctly pick the SAE housing that's needed to mate a generator end to an internal combustion engine..
2) How to best choose the coupling that mates the engine to the generator end
Any thoughts?
Thanks!
Doug
MikeHalloran (Mechanical)
5 Sep 08 11:36
IC engines are typically available with no more than two different flywheel housings.
Single- bearing generators are available with a selection of bellhousings complementary to the range of flywheel housings found on engines of appropriate size.
Single- bearing generators bolt right up to a standard SAE flywheel by means of a flexplate (again, engines are available with a small selection of flywheels, and generators with a larger selection of complementary flexplates.)
You only need to worry about a coupling if you buy a two-bearing generator, which is not a good choice unless you want the engine and generator separated axially, e.g. by a driveshaft.
Generator catalogs usually have the bellhousing/ flexplate details within.  For the engine data, you may need to get information from an application engineer; contacting one is a good idea for other reasons, too.
Mike Halloran
Pembroke Pines, FL, USA
Close Box
Join Eng-Tips® Today!
Join Us             Close
