[b]Upgade Installation 2008 SP4[/b]
I know in the past it has been recommended by people here in this forum to install to a different partition if I wanted to keep a previous installation on the same computer and to also copy or move libraries, templates etc. I looked at the SW site and it seems as though you can actually have 2 versions installed in the same partition if you choose the correct install. Does anyone know or have experience with this?
weevoe
weevoe
RE: [b]Upgade Installation 2008 SP4[/b]
You can maintain installations of several different versions on the same partition - you just need to specify unique installation directories during the install. Make sure you specify unique directories for the executable files and the data that gets installed.
I currently have three versions on my machine, all installed on the same partition.
weevoe
