Can you assign command to collapse items on featuremanager?
Anyone?
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
RE: Can you assign command to collapse items on featuremanager?
I've been trying for years.  No API/macro solution found yet.
great.
well i did something and now i have 2 featuremanagers, 1 on top of the other one.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Grab the bar at the top of the lower FM and drag it to the top.
Read Help > Index section for split
cheers
Shift+C is the default "Collapse all items" shortcut.
cheers
I dont have Others>Collapse all items on my keyboard customize menu.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
I don't remember when that command showed up, but I know it's there in 2007.
CBL,
Big thanks for the Shift+C!!!  One of these days I should get around to digging into some stuff like that to figure how much time I could be saving with hotkeys, etc.
Now if I can only remember how to collapse the feature tree when I get back in tomorrow...
Shift C does something else for me.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
The double window keeps coming back.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Yep, I know it keeps coming back :(  That's why I assigned a keyboard shortcut to the split feature manager macro.
When does it re-appear? What operations are you performing?
I only get a split manager when accessing the config manager in an assy, and the Display States appears.
cheers
There's only one instance I can reproduce occasionally.  If you right-click a component and select View Mates.  It splits the FM and often times forgets to unsplit when you're done.
