fuel additive
fuel additive
fuel additive
We are doing some testing of Jet A and the issue came up of additives. Our vendor tells me that a product called diethylene glycol monomethyl ether is added to the fuel to enhance the fuels lubricity, but he doesn't have any details on this. A google search revealed that it inhibits micro-organism growth but that was all that I could find. Does anyone have any experience with this? This is for use in the USA.
Bob
RE: fuel additive
Per ASTM D 1655 and D 4171:
diethylene glycol monomethyl ether is added as a fuel system icing inhibitor.
RE: fuel additive
Do a Google search under "PRIST" by PPG Chemicals.
This is a fuel system icing inhibitor. Years ago it was also advertised and sold as a icing inhibitor / biocide.
In the late 1970's or 1980's they dropped the biocide from the label. I was told at the time by PPG that they would have to license the product as a biocide and that it was less costly to sell the product as a icing inhibitor only. It can also be used in AVGAS (at lower concentrations) as a icing inhibitor both for the fuel system and to inhibit carburetor icing.
In 30 years of selling the product I have never heard of it described as enhancing the fuels lubricity.
RE: fuel additive
Thankyou for your replies gentlemen.
RE: fuel additive
Pratt and Whitney have a Service Bulletin whose number escapes me at the moment that gives dosage levels for a lubricity enhancer called DCI4A.  It is actually a corrosion inhibitor primarily but does "up" the lubricating properties of the fuel as a by product.  The dose levels are so small that it is only detectable by performing a wear scar test or a rust test.  We have not found a way to detect it, let alone measure the concentration in our fuel in the field.
Hope that helps.
Oh, DCI4A is made by a company called Innospec (used to be Starrion I believe).
RE: fuel additive
Diethylene glycol monomethyl ether is added as an icing inhibitor.  It doesn't do anything to the fuel but lowers the freezing point of the water, I am told.  It has limited capability as a biocide but anything that helps prevent fungus can only be good.  We took many pounds out of a C130 in Singapore after all four engines stopped on taxi out (how lucky was that?!).
Lubricity?  No.  We used to use a lubricity additive sometimes with a special metering bottle attached to the fuelling hose but it was only tiny amounts.  Can't remember what i was called  -  possibly some trade name for Boathouse's DCI14A.
RE: fuel additive
bnrg...
There is a ton of data on jet fuel... but like everything, specifics are necessary.
What's the Spec for Your Jet Fuel?? ASTM D1655-08??? ASTM D6615-06??? foreign equivalent???
Check the spec for approved additives... then start calling...
Regards, Wil Taylor
