SA 334 Gr3 Minimum Design Temperature
What is the minimum design temperature for SA334 Grade 3 tubing in a heat exchanger. I have this tubing available and I am trying to determine if we can use it in a -75 degree F design temperature application.
RE: SA 334 Gr3 Minimum Design Temperature
B31.3-2006 allows a minimum of -150F. That is the code book at finger tips right now.
