ASME equivalent of European Investment Casting Standard
Can anyone tell me what the ASME equivalent is of the European standard for investment casting tolerances (VDG P690)?
The abstract of "ASTM A985 / A985M - 04a" seems to indicate that this standard specifies the casting process and inspection requirements. Does this standard also specify the casting tolerances as does VDG P690 or is there a different standard for this?
Thank you very much for the help on this.
