replacing stacked fractions with "regular" text
For MText, how can I globally replace those pseky stacked fractions?  For instance, I need to replace {H0.7x;\S3#8;} with 3/8 but Find won't do it.
RE: replacing stacked fractions with "regular" text
well, Acad 2008 find & replace will Not change {\H0.6878x;\S1/2;} to 1/2
ToolPac's
Mtext -> Find & Replace Will change {\H0.6878x;\S1/2;} to 1/2
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Autocad 2008
Ozzy -  Does MText Find work on a large selected set of text?  Going through the find/replace one at a time is futile...
Isn't there an unstack selection when you Mtext?  I am out of the country and I don't have my ACAD w/ me however I think you can unstack if you highlight the value and  right click on the highlighted value and keep it unstack ubtil you reverse your selection.
There are several options for fixing this one at a time but I'm trying to fix many drawings with lots of stacked fractions in MText in each.  I'll try StripMText from lpseifert and report back.  Thanks all!!!
i knowe one tool, which can replace stacked fractions.
But it's a german tool (mnu and *.vlx).
http://www.cadmaro.de/downloads/freeware/bw_finrept.html
Install the programm, make a support path, load the mnu...
I can help with the translation.
Lothar
ADT 2004
