AutoCAD won't save layer properties???
I have run into this before and can't seem to find my notes on how to resolve it.  When I am in a drawing, I freeze some layers and save the drawing.  Upon reopening the drawing, the layers that I had previously frozen, are active again.
Help!  Does anybody know what setting changes this?
Thank you.
RE: AutoCAD won't save layer properties???
Are you freezing the current drawing, or an Xref drawing?
Maybe someone is working on the Xref and unfreezing?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Thanks for the suggestion.  I finally found my list of problems/solutions.
The variable 'visretain' needs to be set to '1'.  If set to '0', layer properties (frozen, off, etc) will not be saved.
