Combining dimensions into one note or other dimension?
Is it possible for me to combine dimensions into one dimension leader?  For example.  I have a shown dimension for the drill diameter of a tapped hole.  I'd like to attach to that the countersink angle, the countersink dimension and then the thread information.  Something like this would be in the drawing.
<dia symbol> .xxx DRILL - x.xx DP
90<deg symbol> CSKINK to <dia symbol>.xxx
thread callout.
Back in Pro/E (sorry) I could grab the symbol information from various shown dimensions and build a parametric note that would update automatically if I changed the values in the 3D model. I'd like to be able to do the same in V5R18 if possible.
Thanks....
Fighter Pilot
Manufacturing Engineer
RE: Combining dimensions into one note or other dimension?
One thing you might try is right clicking on the dimesnion and creating a positional link and or a oreintational link to the tapped hole dimension OR note. That way when you move the main note, everything goes with it... Like 'tieing' GD&T to a dimension.... Again, just my 0.02
