Code to Determine if SolidWorks is Open
I would like to be able to run a macro with or without SolidWorks being open.  How do you write an if statement to determine if SW is running and then open it if it is not?  As a guess, I tried:
Set swApp = GetObject(, "SldWorks.Application")
If swApp Is Nothing Then
    Set swApp = CreateObject("Sldworks.Application")
    swApp.Visible = True
End If
RE: Code to Determine if SolidWorks is Open
Look at the Task Manager.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
ctopher's blog
I had created something like that a while back.  It went something like this.  I haven't used it in a while, and I don't remember exactly what my purpose was, but I think it worked.
On Error Resume Next
If Err.Number <> 0 Then
    Set swApp = CreateObject("SldWorks.application")
    Err.Clear
    swNotOpen = True
End If
swApp.RunMacro "C:\Macro.swp", "Macro1", "main"
If swNotOpen = True Then
    swApp.ExitApp
End If
Thanks gopack13.  That's exactly what I needed.
