Help for design of rotary system
Hiya all,
I wonder if anybody can help me.
I am designing a large cylindrical type object (approx 800mm tall and in about 400 mm in diameter) and that has slots for locating small items. This cylinder needs to be rotated using some sort of drive and motor mechanism. The speed of movement is not all that critical however smoothness and accuracy are.
My questions are:
What sort of system (pully, worm gear, dc motor, stepper motor) would be best.
How do I go about calculating the motor sizes - do I have to know inertia etc.
Is there any sort of design guide that would help me in the correct selection and sizing of the drive system.
Thanks in advance
Parsnip
My questions are:
Thanks in advance
Parsnip
RE: Help for design of rotary system
How about having an externally splined shaft out of the motor and an internally splined piece connected to the cylindrical object's structure. Then, use a motor control system to rotate the object as needed.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Yes, you do.
"Is there any sort of design guide that would help me in the correct selection and sizing of the drive system."
Yes, it's called and engineering degree.
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
Around here it's called *an* engineering degree.
Don
Kansas City
Is it important:
a. To get the drum to spin at the right speed?
b. To get the drum to get up to speed or stop at the right time?
c. To get the drum to stop in the right place?
d. To get the drum to stop with a particular amount of overshoot?
A.
Putting the slots in the object is also no fun. Machining from the solid or a tube is expensive. Wrapping from slotted sheet is more attractive... except at the joint, where it gets really messy.
The presence of an "indpendently controlled function" suggests that you have two design projects, or one large system design project... none of which you appear equipped to surmount. No offense intended.
One thing you might consider is just wrap a timing belt around the outside of the drum and drive it with a stepping motor. It will require an idler to get enough wrap on the 'pinion'... but it won't need a monster timing belt pulley on the drum... just two discrete teeth.
Mike Halloran
Pembroke Pines, FL, USA
