GAS AND STEAM TURBINE POWER PLANT INTERVIEW
Hi All,
Please, can anyone assist me on the type of questions to expect in an interview on gas and steam turbine power plant.
The company is into maintenance of electricity generation plant. Gas turbine and Steam turbine are used for the electricity generation. The job is for a Mechanical Engineering Maintenance.
Chitel
RE: GAS AND STEAM TURBINE POWER PLANT INTERVIEW
they asked me about gas cycles and vapor cycles, as well as what i knew about the company and the plant. the rest was all about me personally
Luck is a difficult thing to verify and therefore should be tested often. - Me
Hi Carnage1,
Thanks for the reply, your answer is sincerely appreciated.
cheers
Chitel
Knowing a little about the Generator will help and a little electrical.
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
