Solidworks built to run on VISTA x64?
Someone at my company recently purchased a laptop with Vista x64 OS on it. I knew SW2008 was built to run on Vista (32 at least), but I'm wondering if they are working on a patch for 64 or if they currently have anything.
Anyone have any ideas here?
Jay W.
Jay W.
RE: Solidworks built to run on VISTA x64?
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
I will find out. I am installing SolidWorks 2008 sp 4.0 on a 64 bit Vista machine right now.
Bradley
SolidWorks Pro 2008 x64, SP4.0
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Vista OP,
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600
"If it ain't broke, you just haven't looked hard enough." Fix it anyway.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Bradley
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I did not get any errors installing SP 0.0
Bradley
I just looked in the KB and here is what it said:
Solution Id: S-017964
Question:
Will SolidWorks® 2008 run on a Microsoft® Vista™ 64-bit Operating System?
Answer:
Microsoft® Vista™ x64 is supported from SW2008 SP3.1 onward only
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Yea, I called down to tech support last week and they sent me a copy of the latest software (i had originally received SW2008 before 3.1, which is why i had nothing that would load on the vista OS).
Works well now :)!
A 53 MB drawing took 19 minutes 21 seconds to open from company network folder.
To open the same 53 MB drawing from my local 2 raid hard drive it took 25 minutes.
I tried it again from my local drive, over 21 minutes.
I downloaded the "SolidWorks 2009 Pre-Release 2 XP and Vista - 64 bit" SolidWorks professional, size 1.46GB from the SolidWorks website. At 99% in 2 hours 12 minute.
As a little history as to what has happened since starting the Vista Box.
9/3/2008 SolidWorks crashed 2 times.
9/3/2008 Blue screen of death once, late in day.
9/4/2008 SolidWorks crashed closing 610131 drawing I was not saving drawing.
9/4/2008 SolidWorks locked up 2 times.
Bradley
HP xw8600,
64-bit Windows Vista Business
Service Pack 1
