need info on passivation per AMS2700-B Type 6 method 1
I will be passivating 304L SS to this spec and have a few questions pertaining to the SS after passivation.
1. Will the passivated SS be conductive?
2. Will this PROCESS effect laser welding in any way?
3. Will the passivated SS pass the salt/fog testing per
MIL-STD-810F?
MIL-STD-810F?
RE: need info on passivation per AMS2700-B Type 6 method 1
2. It had better not (unless you don't rinse well)
3. It will help
Passivation removes free iron from the surface. If you have bigger problems than that then you need to look at other surface prep methods.
Plymouth Tube
