gasket materials
gasket materials
Exchanger tubesheet is duplex 2205. Channel is carbon steel. The tube fluid is cooling water (1500ppm Chloride, <50DegC). What is the gasket materials for channel flange, Carbon steel, 316L SS, or Duplex Stainless Steel?
Thanks.
Thanks.
RE: gasket materials
Luck is a difficult thing to verify and therefore should be tested often. - Me
http://www.vellumoid.com/gasket2.html
