Mean metal temperature during blowdown
Well not quite a blowdown:
Situation: I have a "reservoir of gas", actually a well of gas under pressure behind a choke. Those familiar with drilling it is the choke located after the choke line in a well intervention / kill situation.
After the choke the gas will flow to a mud/gas separator which operates at atmospheric conditions. I need to perform a calculation to see whether hydrate formation downstream of the choke is possible. Using a simple flash in Hysys, and a 50C upstream temp hydrate formation will occur - however this is effectively a blowdown and the pressure will reduce quickly.
The question is how do I account for metal mass at atmospheric temp (i.e. approx 20C) in the calculation. My feeling is to use the flash temp is too conservative. Any views?
Cheers
Cheers
RE: Mean metal temperature during blowdown
There isn't enough heat capacity in the steel in the system and heat transfer from the air is extremly little.
Best regards
Morten
It is an oil well, scenario being that gas has settled out at the top of the well for some reason (maybe a kick etc). This gives a limited volume of gas - maybe 500ft in the casing is realistic.
What were your thoughts?
Best regards
Morten
