Restoring NX2 files after a crash
We run NX2 on PCs without Teamcentre.
I have had a few crashes lately and am fed up with losing my work. UG appears to save files named xxxx.rol.bin in my Temp directory - is there a way to restore the model from these files?
RE: Restoring NX2 files after a crash
The best way to make sure that you don't lose your work is to 'file early and file often'. That advice was good 31 years ago when I first started to use Unigraphics (AKA, NX) and it's still good advice today.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
If your teamcenter looses connection to the server, you can save outside of Teamcenter.
-Dave Tolsma
http://Tolsnet.com/jobs
http://groups.google.com/group/NX_CAX/
http://groups.google.com/group/plm-exchange/
I nearly mentioned the same thing but the thought of explaining how it works horrified me. Truth be told I've never had any success using that method on the occasions when I've tried, generally because even small things change and make it fall over.
Cheers
Hudson
