tube glass, the mawp or min thickness. More information
Oh excuse please the few data.
Well, the cylinder is made in borosilicate 3.3 or Pyrex.
diameter is 90 mm (3.54")
thickness= 2.5 mm (0.098")(thickness to check)
the working pressure is 30 psig. (max)
temperature max= 120ºC (248ºF )
Referent to thermal shock, the inicial temperature is 32ºC and the final is 120ºC in a aproximately 20 minutes.
the fluid is steam, assume saturate.
thanks advance unclesyd and someothers.
i want to know the mawp or the minimal thickness.
RE: tube glass, the mawp or min thickness. More information
ASTM C599, which is from ASME B31.3. The table lists gage pressure as a function of OD for borosilicate glass at a maximum temperature of 450 deg F.
