TEMA HEAT EXCHANGER - Expansion Joint
Is it true that TEMA standards specify minimum length requirement for an expansion joint used on a shell of a (shell and tubes) heat exchanger?
Thank you.
Thank you.
RE: TEMA HEAT EXCHANGER - Expansion Joint
For a F&F joint there are some practical considerations though, that more or less dictate the radii and straight flanges used, and therefore the length of the joint.
ASME Sec VIII, Div 1, Appendix has rules about minimum radii, and lengths of straight flanges containing connections, such as for V & D.
For a bellows, you get what the manufacturer says you get:)
Sorry for the late reply,
Mike
