Chamfering Question
Chamfering Question
Hello All,
I will try to describe my problem and if it's a simple fix excuse me for asking. I have a yoke shaped part and I only want to chamfer the radius and not the flat leading up to the radius. I have turned off "tangent propagation" and cannot just chamfer the radius it automatically continues on to the flat. Have tried everything to deselect etc. Is it possible?
Thanks in advance.
Thanks in advance.
SolidWorks 2008 SP2
Windows XP Pro, Pentium4 3.00GHz
1GB RAM, Nvidia FX500
Logitech Marble Mouse, SpaceExplorer
RE: Chamfering Question
Do your chamfer then "combine" the bodies.
WP
www.whitney-paine.com
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
ctopher's blog
Chris
AutoCAD 06/08
ctopher's blog
Thanks again, I love this forum.
Dennis
SolidWorks 2008 SP2
Create a very narrow cut (0.0001") cut at right angles to and just covering the chamfer so that it doesn't cut the parent body. This will stop it propagating;(see below) I often use this if I need to stop a chamfer or fillet short of its usual end to simulate the run-out of a tool. In this case I make a sketch for a revolved cut on this "stopped end" face.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
That's pretty smart! Cut the edge that is propogating to stop the chamfer...I like it!
