Need to rename 22 files within an assembly.
Here is the problem. I need to change the names which range from -001 to -022 but different parts get different numbers. In other words, I will only use #'s 1 through 22 but they are already being used by another part.
I tried reassigning numbers through the reference manager but that went nowhere. Any suggestions?
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
RE: Need to rename 22 files within an assembly.
Rename the parts to something else first.
e.g. If you want -001 to become -005 (but -005 is already in use), change the -001 to -005X, then when all numbers have been changed, remove the X.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Flores
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
I made a copy of everything using Pack and Go and put it on a folder separate from all project files. So basically it's an expendable duplicate. Can you guys help me with the procedure for doing this right the first time?
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
thanks you
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
