Reading ASTM Standards
I am a fresh graduate and am just starting off to understand the ASTM standards. For example, I am currently working on an Al part which will be machined out of an extruded bar. I can figure out which heat treatment is to be used. But how do I start to figure out which standard is the right one. Do I have to find a UNS number before anything else?
Any help would be appreciated.
Mike
Mike
RE: Reading ASTM Standards
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Cory
You should use this as a starting point for further studies or investigations.
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
http://www.astm.org/BOOKSTORE/BOS/index.html
If you click on any section you can see the contents of each section.
But, let's go back a step. How did you decide that you need to use an extruded bar product? Seems like something is out of order.
Now I think the next step is to find a UNS number which gives a list of applicable ASTM standards. Then we need to look at the details of each of those standards and select the right one, which is ASTM B221 in this case.
Cory
Ted
