overheating hydraulics
we have several hydraulic systems on site. now and again the hydraulic oil becomes very hot. This results in damaged seals and 'o' rings. Why does the hydraulic oil become so hot and what can be done to prevent it from becoming hot. Im no engineer, but our engineers on site cannot seem to solve this one. thanks
RE: overheating hydraulics
What are the purposes of the hydraulic systems?
A quick one to check is a relief valve that is set too low.
Or, somewhere there is a flow restriction creating a lost-energy pressure drop. Pinched hose. Pinched tubing. Hydraulic lines too small for the flow rates.
Are there any heatexcahgers in the systems?
A circuit diagraphm would be helpful.
What changes or adjustments have been made to the systems since they were first set up?
Has heat been a problem since the systems were first set up?
Ted
There are some applications such as continuous testing of two hydraulic cylinders working against each other all the energy of the work is absorbed by the oil so a massive cooler could be required in this application. Your application is having intermittent overheating problems so if the application is consistent you should either shut the process down during times of high heat or install an oil cooler in the return to tank line. Wherever you put the oil cooler in the system check the pressure in the line and make sure it does not exceed the oil cooler max pressure rating. The size of the cooler will depend on how much excess heat you are seeing the the cost impact of changing the seals.
