PhotoWorks Contest Voting
Right on schedule the images for the August PhotoWorks Rendering Contest have been posted for voting.  We have good interest this month with 13 entries looking for the most votes.  What can you do with a plastic pump bottle?  Check out the submissions to find out and vote while you're there.
Before you leave download the model for the September contest  and get started on your images.  The September contest will have a bit of a twist.  In the past you had to use PhotoWorks to create your image.  For September you'll have the option to use either PhotoWorks or PhotoView 360.
Good luck.
www.robrodriguezblog.com
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org  www.nvtswug.com
SW 2007 SP 2.0
