program to make a wiring Diagram
Hi Guys,
Could someone tell me what is the best application program to make a wiring Diagram...
I usually use Autcad.
Thanks for responding.
Ben
Ben
RE: program to make a wiring Diagram
Keith Cress
What I mean;-
When I do a ladder diagram, I put a subscript under each set of contacts to indicate the line they are controlled from. To the right of each relay coil I put a series of numbers indicating each line controlled by by that coil. Each line is numbered and the line number forms part of each wire number.
For instance the first wire in line 23 will be 231, the next wire will be 232, etc. It takes a little longer to draw, but you get the time back the first time you have to trouble shoot.
Bear in mind that when a plant goes down the cost per minute of down time may be much more than the cost per hour spent on the drawing.
Is there anything out there to automate the numbering?
Bill
"Why not the best?"
Jimmy Carter
I like your scheme. It's nice.
In my case I rarely do ladder diagrams. Most my stuff is pure schematics, gates, transistors, processors, etc. Jobs that have some ladder stuff are usually small enough that I can fit them on to two B size drawings that don't take a lot deciphering.
If I get into a bunch of laddering it's because I'm messing with a PLC. Then the PLC program prints it all out in some cryptic but hopefully functional format.
As for general stuff I believe Viso is often used as it has some nice abilities and you can buy symbol kits.
Used to be lots of add on packages available for Autocad that could do all sorts of this stuff. Then the the current psycho took over as the CEO and Autodesk started screwing their value added people left and right. I know several who threw in the towels. Not sure if an automation package for 'wiring' exists now.
Keith Cress
Bill
"Why not the best?"
Jimmy Carter
Before we bought the AutoCAD package, we used Orcad for generating ladder diagrams. It does provide some smarts, but not as much as AutoCAD electrical.
