Column and shear wall interaction
Hi, everyone.
I've modeled a 23 stories high-rise building, dual system(special resisting moment frame and shear wall). Usually, there will be a column at the intersection of the two orthogonal shear walls. But what we usually do is ignoring this column and not developing the column in our etabs model. I wanna know what's your opinion about this and your methods? Thanks in advance!
RE: Column and shear wall interaction
Zeeshan
Thanks for sharing your ideas.But you know, sometimes, the dimensions of the column would be larger than the width of the shear wall, so the stiffness and corresponding seismic base shear will be different. How to consider this?
Thanks.
Shulu Zhang
I dont think that the size of the column will impact that much in the contribution of base shear, even the coulmn width is double than the Shear wall thickness. Let me try some tests on ETABS to make a conclusion.
Zeeshan
