Tempory structures behind Segmental Retaining Wall
I have a situation whereby an Architect is proposing few temporary structures right behind the wall which is 4.0 ft high the finished surface would have on top patio pavers. The structures are Gazebo with 8 sonotube foundations with min 4.0 ft depth, a glass structure with sonotube foundation and a temporary prefab Coach house with no foundation it sits right on pavers. I am not sure what kind of loads i have to consider from these structures. How would these structures apply loads do i have to consider wind loads from closed structure like glass house and coach house. For the design of wall i am going to surcharge it using 100-150 psf live load.
Thanks for all your suggestions.
RE: Tempory structures behind Segmental Retaining Wall
The use of SRWs around and along waterways amd lakes with a paver surface and miscellaneous structures on the upper paved areas is a common application. The engineers are well versed in the varous methods to handle the design of the walls and attaching/accomodating the "people" elements like temporary structures, railings and utility posts/attachments.
Dick
