Design for Generator foundation pad
I am looking for design of generator foundation pad. In calculation of generator pad, what factors to consider. Generator is only 6600 lbs. Area required for footing is not much, but if someone can help regarding some calcs, it's appreciated.
RE: Design for Generator foundation pad
I strongly suggest that you engage the services of a local structural engineer to help with your structural needs.
Mike McCann
MMC Engineering
the generator pad. What information else is
required, do you need generator kVa's or electrical
information. I think you can suggest me about vibration
loads or something structurally to consider while design ing concrete slab on grade pad supporting generator loading.
This question has been answered previously, use the google search at the top of the page and also check out sliderules website.
