home brew Heat Transfer
I'm looking to come up with the governing equation for the Temperature of my wort (stuff that gets boiled before making beer) as I chill it with a simple heat exchanger. It's a copper coil submerged with tap water running through it. Being out of school for a year or so it seems I've forgot a lot and I'm trying to exercise my brain again. The way I see it is I have two places where heat is being transfer if I neglect radiation. I have heat lost to the ambient air through the kettle a simple qair=hA(Tair-Tkettl). Heat transferred to the tap water through the pipe that will be a function of the surface area of the chiller and inlet temp of chiller. If I remember right I'll add the q's together and set that equal to the change of internal energy (dU) of the wort.
RE: home brew Heat Transfer
I took my 1/4" cooper line an put it inside a garden hose. On each end I used a 1/2" tee with the cooper line coming out the straight run. The tees are affixed to the hose with normal tapered fittings and clamps. Now the tricky part. You need a comprssion fitting 1/2" NPT to 1/4" compression. You take the fitting over to the drill press and drill it out to the OD of 1/4" cooper. This way the cooper can go all the way though the fitting. Compress the fitting and its sealed. I coiled it up in a 12" coil with 25' of cooper (typical roll).
I then sphyon the wort slowly through the 1/4" and have cool tap water running. Forced convetion on both side, huge transfer rate.
and I will make a contour flow chiller one day. It's just not in my invintory yet.
