Standardized wire colors for starting, charging, head and tail lamps
Hi all,
Can any one tell me if SAE has come up with any new standards that expand on the basic color codes found in SAE
J1292 (Automobile, Truck, Truck-Tractor, Trailers, and Motor Coach Wiring). Such as including Ignition,and headlamp standard colors? I know Europe is using a DIN standard.
Also with respect to automotive drawings, is there an SAE standard for the sheet(aka cell) and page numbering or is that a question for IEEE?
Thanks for your help
RE: Standardized wire colors for starting, charging, head and tail lamps
Luck is a difficult thing to verify and therefore should be tested often. - Me
