CROSSED LINK BETWEEN UG-36 AND UG-39?
In case of openings in flat heads, I am not fully sure of the logic linking UG-36 and UG-39 in ASME VIII Div. 1. As a first "general" appearance in the "OPENINGS AND REINFORCEMENTS" subject, one could think that openings meeting UG-36 requirements do not need to be further checked for reinforcement, and that´s all. But later, when reading UG-39 (a), one more requirement "do not exceed one-fourth the head diameter or shortest span" appears, and hence openings meeting UG-36 requirements but exceeding that one-fourth limit would still need reinforcement calculations according to UG-39.
Furthermore, would all the rules for multiple openings apply as far as only one of the openings in a group of three fails to meet size requirements? At first glance I think "yes" but again, perhaps is it a too-much conservative point of view?
I try to illustrate it with my proposed interpretation in the attached PDF for multiple openings. Am I right? Could anyone confirm or add some more info?
Many thanks in advance,
J.I.G.C.
Chemical Engineer
