Export Or Copy Detail Views
Is it possible in SolidWorks 2008 to export or copy a dimensioned detail view from one part drawing to another (different) part drawing (in this case extruded aluminum profiles) when the dimensioned detail is identical on several parts?
RE: Export Or Copy Detail Views
Not directly, but you could "Save as" the drawing a jpeg and then crop and insert the detail view as an image into the new sheet.
cheers
Yes, Save As copy existing drawing...give new drawing number.
Close, then reopen, change referenced part to new part.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
ctopher's blog
