insert color or texture in drawing
i need to insert the color i have in the model, to make the drawing color coded,  some faces or parts to be in a light color and others to be in a dark one.
the way i do it is using appearance in view in the model and it is reflect on the drawing but not while printing , i also want it to be show while printing , can you help me please
thanks
RE: insert color or texture in drawing
To clarify ...
The drawing views are set to Shaded or Shaded with edges mode, and appear correctly when the sheet is viewed, but when printed the views do not show colours or even grey shades?
Does the Print Preview show correctly?
cheers
ya that was the case , but it was in the printing settings, it is fixed now , thank you so much
