Suitability of ASTM A216 Gr WCB for service
Is there a decent site that will allow me to assess suitability of WCB for use with certain media in pipeline systems and valves?
RE: Suitability of ASTM A216 Gr WCB for service
ASTM STANDARD RELATED BOOK TO STEEL PIPING, TUBING,& FITTINGS WILL BE A GOOD REFERANCE TO YOU .
ASTM  A216 : IT HAS THREE GRADE AS WCA,WCB&WCC ,IT COVERS CARBON STEEL CASTINGS FOR VALVES, FLANGES,FITTINGS FOR HIGH TEMPERATURE SERVICE .
               GR. WCA          GR.WCB         GR.WCC
  YIELD POINT  30000            36000           40000
   MIN (PSI)
Check Chemicl engineering Hand Book (Perry) this gives usability of various material in various media. WCB is a common CS material, if you could get hold of ASME Sec II D then you could get the allowable stresses at different temperatures for designing purpose. Also ANSI B 31.3 could provide you with necessary information.
If you do not have Chemical Engineering Hand Book give the application i'll try to look and post you.
Good Luck
