Cable Fault Location by using the exhalation of the Fault
Hello !
First of all: Sorry for my bad english, but im from Germany, so english is unfortunatly not my mother language ;)
Im working at a big company at energy supply and im doing the cable fault location there, using the standard stuff like TDR, Arc Reflection , burning and so on.
But i also heard that it should be possible to locate a cable fault without opening the ground via the exhalation of the Cable Fault/Gas.
The Cable Faults are often smelling really bad, so it should work normally, i also thought about drilling a dog to that find that smell.
Problem could be that you cant go out with your dog anymore, because he finds alot of problems on/in the ground :D
Some Informations about the used systems would be nice.
Thanks in advance !
Lorenz
Thanks in advance !
Lorenz
RE: Cable Fault Location by using the exhalation of the Fault
Marmite
