New to Cosmos. Model conrod help
Good morning all,
I race model planes, and we tune the engines to get the most out of them. I have made some conrods, that have failed, but rather than just beefing them up I thought I'd use works cosmos to see where they need improving.
I have never used cosmos, just had a bit of a play with the cosmos express, but I don't think I'm putting the correct information in,
I have restrained the bottom bore, and put a load on the top bore vertically, but this only seems to deform the top portion by stretching.
Could someone please give me some guidance or maybe point me to a tutorial that will get me started.
Thanks in advance, Mark.
Tyan Mobo 2xDual Core Opteron 2214
4gb Ram
Quadro FX 3500
150gb Raptor Stripe Raid
XP Pro x386 SP2
RE: New to Cosmos. Model conrod help
Try shot peening your conrods.
I'm not sure but i think the failure occurred due to lack of oil, but I'd like to check it out and also learn a little about cosmos.
What software would give me what I'm after, Ansys? ProE?
4gb Ram
Quadro FX 3500
XP Pro x386 SP2
If you're spending real money and want real answers, hire a real analyst to do this for you.
Sounds like he is trying to use a full versioned program, just lacking the know how. I agree with the others, if you want a realistic analysis, you'll have to get someone that knows what they are doing.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Beefing up does not help much, it increases inertia loads.
Can you fabricate titanium?
"Former racing person"
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
