Ti Gr. 5 fastener with chersterton 785 and loctite
Hey,
I have a two procedures in front of me where one says that I should use chesterton 785 on the threads of a Ti fastener and some loctite on the fastener head, the other says the opposite..
Should I use chersterton 785 on the threads to minimize the risk of galling? Between, the fastener and nut are of the same material.
thanks!
thanks!
RE: Ti Gr. 5 fastener with chersterton 785 and loctite
Chesterton 785 is a lubricant to provent galling, so its use on threads makes most sense.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thank you
Ted
I dare not remove chersterton from the procedure..
Cory
