adhesive for nylon 6
Hi experts,
Here's the scenario.
- I need to glue together four panels of nylon (forming a box).
- After glued they will be submerged in water for the rest of their life.
- The water will contain electrolyte (KOH - Potassium Hydroxide)
- The operating temperature of the water will be around 180° F (max 200° F)
- The nylon will surround several stainless steel plates
As you may have guessed, this is for an HHO Generator (electrolysis).
in short:
- adhesive should be waterproof
- adhesive should resist high temperatures
What do you suggest? Any special brand?
in short:
RE: adhesive for nylon 6
Formic acid is best.
Superglue might work if the load is low and the joint design is good.
Why not just buy a box from an electrical supply house. They make a wide range of boxes from PVC which should have the chemical stability you require. Temperature resistance will be marginal.
If you need higher temp than PVC, try to find a PP box or just cast one from polyester or epoxy or lay up one fro figreglass reinforced polyester.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
How and where would I apply the formic acid?
Cory
Dip the edge of the nylon in until it softens a bit then press the surfaces together.
Welding nylon normally requires expensive tooling but will do a good job.
The plastic inline fuel filters commonly fitted to cars in the 80s were 2 nylon half shells welded ogether at the centre flange with formic acid.
It is to long a time since I did it, but I think a fillet can be built by dissolving some scraps of nylon in the formic acid to make a syrup or paste, then laying it in the corners. Use concentrated formic acid. 90% concentrated should do. Be careful it is corrosive and has noxious fumes.
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
